Finishing Services
Electroless Nickel Plating
n/a
Smooth, glossy finish
Can be applied with
Alodine
Electroless nickel plating (ENP of NiP) is a reaction that deposits a nickel-phosphorus alloy onto the surface of a metal. It uses a purely chemical reaction to induce plating and does not leverage electricity. Though this process takes much longer than electroplating, advantages are a more uniform thickness over even the most complex surfaces (due to not having to rely on varying electric fields), as well as superior wear and corrosion resistance. The standard specification for ENP in North America is MIL-C-26074E, with various grades specifying thicknesses from 0.0003-0.002”.
Design considerations
Our standard offering for ENP adds thickness between 0.0003”-0.0005”, although we can achieve 0.00005” up to 0.002″ if specified in a drawing.
Scaling CNC to Casting Guide
How to Transition from CNC Machining to Casting for Production Scale Identifying the Right Parts for Casting CNC vs. Casting: Fundamental Differences Casting Process Selection (DFM) Design Adjustments for Transitioning from CNC to Casting Casting Design for Manufacturability (DFM) Considerations Materials & Performance Considerations Hybrid Strategy: Casting + CNC Finishing Simulation & Validation Tooling & […]
Prototyping Lead Time: Process Timelines and How to Reduce Delays
Prototyping lead time is often framed as a simple question: “How long will it take to get my part?” In reality, the answer is rarely determined by machine time alone. A prototype expected in days can easily take weeks—not because of production constraints, but because of delays in quoting, design iteration, manufacturability feedback, and supplier […]
