Custom Sheet Metal Services
Fictiv’s sheet metal solutions deliver the consistency, reliability, durability, and quality you expect from Fictiv, including material and finishing options to support your applications.
Quality inspections on every part
Joby
Meta Logo
7 certified Materials,
11 Finishing Options
Material Certification, Certificate of Compliance, Advanced Inspection
Hardware Installation, Mechanical Assembly
Domestic and overseas lead times available
Our Sheet Metal Services
Cutting
Laser cutting, plasma cutting, CNC turret, punching, shearing, water jet cutting
Forming
Press brake bending, stamping, rolling, custom form dies
Welding
MIG welding, TIG welding, Spot welding, Robotic welding
Finishing
Full RAL catalog Powder Coating, Plating, Media Blasting
Sheet Metal Materials
Aluminum
Brass
Bronze
Copper
Stainless Steel
Steel
Titanium
Aluminum
Aluminum is a lightweight and highly versatile material that is widely used in various industries. It offers a unique combination of properties including high strength-to-weight ratio, excellent corrosion resistance, malleability, and good thermal and electrical conductivity. These characteristics make aluminum an ideal choice for applications where weight reduction, durability, and efficient heat transfer are important factors, like engine blocks, heat exchangers, and other transportation components.
Mill Lead Time:
As fast as 3 days
Alloys:
• 2024-T3 – High strength aerospace alloy; limited formability and poor corrosion resistance (often requires coating)
• 3003-H14 – Very good formability; ideal for complex bends and cosmetic parts
• 5052-H32 – Preferred sheet metal alloy; excellent formability, corrosion resistance, and weldability
• 6061-T6 – Higher strength; limited form ability and best suited for simple bends
• 7075-T6 – Very high strength; poor formability and not recommended for bending, best for flat or minimally formed parts
Finishing:
Alodine, Anodizing Types II, III, III + PTFE, ENP, Media Blasting, Nickel Plating, Powder Coating, Tumble Polishing.
WORKFLOW AUTOMATION
Why Fictiv for Sheet Metal
Sourcing simplified for custom sheet metal manufacturing
1-500+ Parts As Fast As 2 Days
  • Guided expertise available pre- and post-sale
  • Flexible application options
  • Tolerances as low as +/- 0.005”
  • Variety of metals (aluminum, steel, brass, copper)
  • Cutting, forming, welding
  • Finishing options (Anodizing, Chem Film, Plating, Media Blasting, Tumbling, Powder Coating with full RAL Color Matching)
Download our Sheet Metal Design Guide
Learn all about sheet metal fabrication and how to design a part for sheet metal here.
Download
Finishing Options for Sheet Metal
Chem Film Aluminum Clear, gold Media Blasting, Tumbling, Type II Anodizing* Type III Anodizing*, Type III Anodizing with PTFE*
Anodizing Aluminum Clear, black, grey, red, blue, gold Media Blasting, Tumbling, Chem film*
Media Blasting Aluminum, Steel, Stainless Steel, Brass, Bronze, Copper All post processes except Electropolish and Powdercoat
Powder Coating Services Aluminum, Steel, Stainless Steel Pantone or RAL color matching
Tumbling Aluminum, Steel, Stainless Steel, Brass, Bronze, Copper All post processes except Electropolish and Powdercoat
*Additional finishing options include CHROMIC ACID ANODIZING, CADMIUM PLATING, COPPER PLATING, GOLD PLATING, SILVER PLATING, and more. For materials not listed here, please contact us directly.
#fictivmade
Sheet Metal Parts Made By Fictiv
Find Out How We Solve Our Customers’ Toughest Challenges
JOE TEDESCO
JOE TEDESCO
Lead Aerospace Engineer
Heliospace
ANDREW WILLING
Mechanical Engineer
HEBI Robotics
JON HOBGOOD
Unrivaled customer service
"Fictiv does an incredible job connecting my needs as a customer to those suppliers that have the capability, the right competitive cost, and the capacity to build my product and get it to me in a very rapid cycle time."
JON HOBGOOD
Vice President,
Advanced Manufacturing and Automation
Honeywell Aerospace
Get a quote now
Learn More About Sheet Metal
ARTICLE
Progressive Sheet Metal Stamping: When to Use It for Complex, High-Volume Parts
In high-volume manufacturing, repeatability determines success. Scaling projects from prototypes to hundreds of thousands of units requires a shift in…
Read more >
ARTICLE
Laser Welding: Process, Advantages, Applications, and Design Guidelines
Laser welding is a precision joining process that uses a focused laser beam to fuse metals with minimal heat input,…
Read more >
ARTICLE
When designing a product, consider all factors that will contribute to its success throughout the development process. For most companies,…
Read more >
