Finishing Services
Vapor Polishing
N/A
Applications
Enhanced cosmetic appearance, near optically clear applications
Smooth and glossy
Vapor polishing is a manual process that uses a vaporized solvent to melt the surface of the material so that it flows and fills in microscopic scratches or voids. The surface is polished at a microscopic level and no material is lost in the process, similar to vapor smoothing for 3DP.
This process results in a near optically clear surface finish and is commonly used in applications where high levels of transparency are required.
Design considerations
  • Parts with uniform wall thicknesses will generally smooth more evenly
  • Radiused corners generally produce better results than sharp corners
