round check mark
ISO 9001:2015 certified QMS
round check mark
45+ Certified Materials, 13+ Finishing Options
round check mark
NADCAP and NABL approved manufacturing partners
round check mark
Hand Metrology, Laser & CMM Inspections
round check mark
Hardware Installation & Mechanical Assembly
Why Fictiv for CNC Machining
Sourcing simplified for custom CNC Machining
Made As Fast As 1 Day
  • list check mark Pre- & Post-Order DFM
  • list check mark Large Parts (Up to 34 feet)
  • list check mark No Minimum Order Quantity
  • list check mark Tight Tolerances (+/- 0.0001”)
  • list check mark Wide Range of Metals and Plastics
  • list check mark Finishing Options (Anodize, Plate, Chem Film)
  • list check mark High-Quality, Complex Geometries
  • list check mark Undercuts, Threads & Holes
cnc machining
Our CNC Machining Services
Precision Machining Tolerance
Metals, PEEK, And
ULTEM with Drawing
Other Plastics
with Drawing
No Drawing
Linear Dimension +/- 0.0025 mm
+/- 0.0001 inch
+/- 0.05 mm
+/- 0.002 inch
ISO 2768 Medium
Hole Diameters
(Not Reamed)
+/- 0.0025 mm
+/- 0.0001 inch
+/- 0.05 mm
+/- 0.002 inch
ISO 2768 Medium
Shaft Diameters +/- 0.0025 mm
+/- 0.0001 inch
+/- 0.05 mm
+/- 0.002 inch
ISO 2768 Medium
Part lengths of up to 48" are available on our platform process dependent. Please inquire about anything larger. Tolerances listed here are minimums for an ideal case. Looser tolerances may be required depending on process, material choice, or part geometry.
Download Tolerance Chart
CNC Machining Materials
A2 Tool Steel
ABS
Acrylic
Aluminum
Brass
Bronze
Cast Iron
Copper
Delrin
Garolite G-10
HDPE
Invar
Kovar
Magnesium
Nylon
PEEK
Polycarbonate
Polypropylene
PPS
PTFE
PVC
Stainless Steel
Steel
Titanium
Tool Steel
Torlon
UHMW
Ultem
Zinc
A2 Tool Steel
Mill Lead Time:
As fast as 7 days
Finishing Options:
Try Materials.Ai
MaterialsAI
Finishing Options for CNC Machining
Chem Film Aluminum Clear, gold Media Blasting, Tumbling, Type II Anodizing* Type III Anodizing with PTFE*
Anodizing Aluminum Clear, black, grey, red, blue, gold Media Blasting, Tumbling, Chem film*
Hand Polishing Acrylic Enhanced Cosmetic Appearance
Media Blasting Aluminum, Steel, Stainless Steel, Brass, Bronze, Copper All post processes, except Electropolish and Powder Coat
Powder Coating Services Aluminum, Steel, Stainless Steel Full Pantone or RAL color catalog
Tumbling Aluminum, Steel, Stainless Steel, Brass, Bronze, Copper All post processes, except Electropolish and Powder Coat
Vapor Polishing CNC Polycarbonate (Clear, Black) Enhanced Cosmetic Appearance, Near Optically Clear Applications
*Additional finishing options include chromic acid anodizing, cadmium plating, copper plating, titanium anodizing (blue anodizing), gold plating, silver plating, and more. For materials not listed here, please contact us directly.
Download our CNC Design Guide!
Learn how to control costs, streamline the design and machining process, and ensure quality CNC drilling, milling and turning outcomes.
Download
WORKFLOW AUTOMATION
#fictivmade
Custom CNC Machining Parts Made By Fictiv
JOE TEDESCO
Production at the pace of innovation.
JOE TEDESCO
Lead Aerospace Engineer
Heliospace
Download Case Study >
Brian Burns
30% lower overhead costs.
Brian Burns
Co-Founder,
Catalyst Engineering
CNC Machining Service FAQs
Fictiv provides a variety of lead times to match your budget while maintaining your project timeline. We can supply CNC parts as quickly as one day.
Our machines are capable of tolerances as tight as +/- 0.0001 inches.
What types of materials work with your CNC machining services?
Our online instant quoted materials can be found here. Not seeing what you are looking for? You can always request a custom material through our custom RFQ process.
At Fictiv, we know how critical information security is, especially when working with high-value design IP. That's why we designed our platform with elite-level security and confidentiality as a top priority. From log in to file upload to part fulfillment, you can rest easy knowing that your IP is safe within our secure Digital Manufacturing Ecosystem. Need extra assurance? We're happy to sign an NDA, simply fill out a request here.
Can you accommodate rush orders or expedited delivery for CNC machining?
Yes. Speed is the standard at Fictiv, but never at the expense of quality. We offer a variety of costs and lead times to match your requirements. However, if you require faster delivery for a specific quote, please reach out to your sales representative to see if we can accommodate your request. We will do everything we can to achieve your desired timeline.
Are you able to work with complex geometries or 2D drawings for CNC?
Fictiv not only supports complex geometries, but we pride ourselves on being able to produce and deliver complex parts. Our online manufacturing platform enables 2D drawing uploads and generates 2D drawings. Our quoting engine then analyzes the drawings for configuration details and special callouts.
Our platform provides free Design for Manufacturability (DFM) feedback pre-order on all quotations. There are two categories of this feedback: 1. “Warning” indicates a design that requires a closer look, but can still proceed with ordering. 1. “Failure” indicates the component has a significant risk of failure during manufacturing. In this case, a design revision must be uploaded prior to check-out. We also have a team of engineers available to provide DFM feedback via email or phone.
Fictiv is ISO 9001 certified, ISO 13485 compliant, and has NADCAP and NABL approved manufacturing partners.
Get Custom Parts Delivered As Fast As 24 Hours.
Instant pricing & lead-time options
Learn More About CNC Machining
ARTICLE
Prototyping Lead Time: Process Timelines and How to Reduce Delays
Prototyping lead time is often framed as a simple question: “How long will it take to get my part?” In…
Read more >
ARTICLE
CNC vs Die Casting Qualification Scorecard
Quick Evaluation Tool for Process Selection Compare die casting and CNC machining to determine the best process for your prototyping…
Read more >
ARTICLE
CNC machining involves far more than simply uploading a CAD model and cutting parts. Every part is shaped by the…
Read more >
