Uplevel Production with Integrated Mechanical Assemblies
Fictiv accelerates innovation by delivering complex mechanical and welded assemblies through one powerful digital manufacturing platform—no vendor juggling, no friction. We help teams move faster, cut risk, and scale with confidence across aerospace, robotics, medical devices, and beyond.
Access off-the-shelf components and custom mechanical parts - all in one place
Single-source solution for fabrication, welding, and assembly
Expert guidance from design through final assembly
Global supply chain management without the complexity
From prototypes to full assemblies — no minimum order requirements
** Fictiv assemblies must contain parts manufactured by Fictiv.
Why Leading Engineers Choose Fictiv for Assembly
Eliminate vendor complexity with one accountable manufacturing partner.
Fictiv unites fabrication, welding, and assembly in a single digital platform to accelerate timelines and deliver precision at scale.
Talk To Our Team
parts image
The Era of Fragmented Mechanical Supply Chains is Over
Advancing from single-part fabrication to integrated assemblies with one digital manufacturing partner.
Quality You Can Trust
Precision parts with full inspection reports and traceability every time.
  • Faster path from design to integrated assemblies
  • Lower the risk of defects and rework by partnering with Fictiv
  • Design with confidence through instant platform DFM
  • Fictiv’s partnership with MISUMI gives you instant access to 80 sextillion parts
parts image
background
Support for Semi-Permanent and Permanent Assembly
Semi-Permanent
Mechanical assembly for sheet metal, CNC, 3D Printed, urethane cast, and injection molded parts
Riveting
Heli-Coils/locking inserts
Bolt Installation
Off-the-shelf components
Permanent:
Welding for sheet metal parts
MIG
TIG
Laser
Spot
Robotic
From Mechanical to Welded Assembly
As designs evolve from prototype to production, certain assemblies demand the permanence and strength of welded joints. Fictiv extends the same precision and traceability-from mechanical assembly into advanced welding capabilities -delivering seamless transitions between fastening and fusion-based joining methods.
card
MIG Welding
card
TIG Welding
card
Spot Welding
card
Robotic Welding
Leading Humanoid Robotics Company Uses Fictiv for BOM Cost Down and Supply Chain Orchestration
CHALLENGE
  • Speed of design iterations was a challenge for existing Tier 1 & 2 contract manufacturers
  • Internal supply chain team under resourced, not enough industry experts aside from design and software
  • High-mix, low-volume production with rapidly evolving requirements and exacting finishes
FICTIV SOLUTION
  • Dedicated resources for supply chain orchestration and program management
  • On-call experts providing finishing, design, assembly, and lifecycle development support
  • End-to-end support for global sourcing, DFM, BOM benchmarking and cost-down analysis
  • In-region quality inspections and oversight with global production options
RESULTS
  • Supplier consolidation to enable assurance of supply, faster innovation cycles and speed to market
  • Managed supply chain orchestration for all custom mechanicals
  • Facilitated scaling with CMs, attraction of new investors, and supply chain resilience
icon
CNC Machining
icon
Sheet Metal Fabrication
icon
3D Printing
icon
Injection Molding
icon
Die Casting
icon
Actuators
icon
Finishing & Anodizing
