Why Choose Fictiv?
Digital Manufacturing Built for What's Next
Instant quotes. AI-powered DFM. A vetted global network. Expert support. One platform that gets your parts made right, fast, and at scale.
Fictiv manufacturing expert reviewing instant quotes for CNC machining, injection molding, and 3D printing
THE FICTIV DIFFERENCE
Why teams trust Fictiv
Proven quality
ISO 9001:2015 certified, inspection per drawing requirements, and full inspection traceability.
Global network that scales
250+ vetted partners across 5 regions, so capacity is never the bottleneck.
Manufacturing without friction
Instant quoting, AI-powered DFM, and real engineers from first quote to delivery.
One partner for every process
CNC, molding, sheet metal, 3D printing, and more.
Customer results
How teams scaled to production with Fictiv.
Compare Fictiv to marketplaces
How Fictiv compares to marketplaces and traditional shops.
PEOPLE, NOT PORTALS
Most Platforms Give You Software. We Give You Experts.
From first quote to final part, get direct access to manufacturing engineers who know your project, answer fast, and own the outcome.
Fictiv program managers reviewing an order dashboard
Dedicated program management—from part to delivery.
Manufacturing engineers discussing a project on the factory floor
Built to spec. With you in the loop.
Precision-machined metal and plastic parts made to spec
Your parts. Made to spec.
HOW WE COMPARE
How Fictiv outperforms the competition
The platform, network, and team others are still trying to build — Fictiv has been delivering for years.
Capability Typical machine shop Digital marketplaces Fictiv
Tolerances Varies by shop; you won't know until you've qualified them Platform-driven specs with no enforcement
±0.0001" across milling, turning, and EDM — guaranteed, not shop-dependent
Capacity Single-site; surges strain scheduling and lead times Broad but unvetted — quality at scale is unpredictable
250+ vetted partners across 5 global regions — flex up without qualifying new suppliers
Finishing Often outsourced; adds lead time and coordination overhead Buyer arranges independently; no coordination
Plating, blasting, dyeing, anodizing, custom coatings — all under one order
Assembly Limited; full BOM builds are rare and hard to scale Not offered
Welding, kitting, and full BOM builds — one partner from part to finished product
Speed Manual quoting; lead times shift with shop workload Instant quotes, but no accountability on delivery
Instant quotes backed by reliable lead times — speed you can actually plan around
Quality docs Depth and standards differ everywhere; no guarantee Little to no oversight; documentation is buyer's problem
QMS, CMM reports, advanced GD&T, and CoCs on every order — no chasing paperwork
Support Not built for multi-part program management Self-serve only; no escalation path
Real engineers and dedicated PMs on every program — not a chatbot, not a ticket queue
Risk Single-region; tariff and disruption exposure falls on you Lowest-bidder sourcing with no built-in resilience
Audited suppliers and multi-region redundancy — disruption absorbed, not passed through
Tolerances
Fictiv
Capacity
Fictiv
Finishing
Fictiv
Assembly
Fictiv
Not offered
Speed
Fictiv
Quality docs
Fictiv
Support
Fictiv
Risk
Fictiv
A GLOBAL NETWORK
Capacity that scales with you
In-region manufacturing across five global manufacturing hubs, 250+ vetted partners, and full supply chain visibility on every order.
Map showing Fictiv production across five global manufacturing hubs
Production across 5 global manufacturing hubs
Fictiv engineers performing quality and supplier performance checks
250+ audited manufacturing partners
Fictiv order dashboard showing full visibility from quote to delivery
Full visibility from quote to delivery
5 GLOBAL REGIONS
200K+ MACHINE HOURS / MO
250+ VETTED PARTNERS
5,000+ COMPANIES SERVED
42M PARTS PRODUCED
What's driving your build?
Four reasons teams choose Fictiv. Start with the one that matters most right now.
Earth viewed from space, representing speed at scale
SPEED
Ship hardware faster
From design to loading dock in days, not months — instant quotes, AI-powered DFM, parts in as fast as 1 day.
Cut your lead time
Engineer holding a precision-machined part
CONTINUITY
One partner, prototype to production
No re-qualification. Your parts history, DFM notes, and quality docs carry from first article through full-scale production.
Scale without re-qualifying
Fictiv manufacturing facility interior
RESILIENCE
A supply chain built for what's next
Tariff shifts and single-source failures absorbed by a multi-region network with built-in tariff management.
De-risk your supply chain
Precision-machined mechanical assembly
COMPLIANCE
Pre-audited. Certified. Mission-ready.
Skip the 6-month supplier audit — AS9100D, ISO 13485, and Nadcap-approved partners with full traceability on every order.
Skip the 6-month audit
QUESTIONS
Quick answers
How fast can I get parts?
Instant quotes in minutes, CNC parts as fast as 1 day, 3D printed parts in 24 hours, sheet metal parts in 2 days, and injection-molded T1 samples in about 10 days, depending on geometry and material.
What quality certifications do you support?
ISO 9001:2015 quality certification and manufacturing partners certified to AS9100 Rev D, ISO 13485:2016, and IATF 16949:2016. Inspection reports, CoCs, advanced GD&T, and full material traceability on every order.
Can Fictiv scale from prototype to production?
Yes. The same platform carries your parts history, DFM guidance, and quality docs from first article through full-scale production, so you avoid re-qualifying a supplier mid-program.
How is Fictiv different from other online manufacturing services?
Most online manufacturing platforms connect you to whoever bids lowest. Fictiv works differently: 250+ vetted manufacturing partners — not lowest-bid auction winners.
That network has delivered 41M+ custom parts to 3,000+ trusted brands, backed by four things competitors rarely combine:
  1. Unlike marketplace-style platforms that simply connect you with the lowest bidder, Fictiv actively manages quality, logistics, and supplier performance on every order. Our 95.4% on-time, in-full delivery rate reflects this operational rigor. Whether you're building a single prototype or running a production program at 500,000+ parts, the platform, quality standards, and team behind you don't change.
  2. A network that's managed, not just listed. Every partner goes through a rigorous onboarding audit and ongoing performance management. Five manufacturing regions and GlobalFlex tooling let you shift work for cost, speed, or supply chain continuity without re-sourcing.
  3. People, not a ticket queue. Dedicated program managers and in-region quality engineers on every order. When one customer was quoted 20 weeks elsewhere, Fictiv delivered in six to eight.
  4. Simplified sourcing for your entire BOM, throughout the entire product development lifecycle. One partner, all your custom and standard parts, finishing, kitting, quality, and even assembly.
Upload your design to get an instant quote and see the difference firsthand.
How does Fictiv protect my intellectual property?
Fictiv provides enterprise-grade IP protection at every stage of the manufacturing process. Your CAD files are anonymized before being shared with manufacturing partners—no supplier sees your company name, project context, or full assembly. Only the manufacturing partner awarded your order receives access to your design data (no mass bidding). All Fictiv manufacturing centers operate under strict NDAs as legal extensions of Fictiv. Our processes are SSAE18 SOC2 audited for information security. For additional protection, we offer mutual NDA agreements or can sign your company's proprietary NDA. Our Secure+ program provides access to an exclusive network of suppliers with enhanced physical and digital security controls for robotics, aerospace, and other IP-sensitive industries.
Ready to build?
Upload a design for instant pricing, or talk to an engineer about your program.
