Finishing Services
Zinc Plating
Clear: light blue coating; Black: glossy black coating
Smooth finish, does not hide machine marks
Can be applied with
Media Blasting, Tumbling, Passivation
Color Options
Zinc Plating Black Zinc Plating
Black Zinc Plating
Zinc Plating Clear Zinc Aluminum
Clear Zinc Aluminum
Zinc plating, which is also known as galvanization, is applied to prevent the surface from oxidizing or corroding. This process is done by coating the part in a flux and dipping the part into molten zinc. The molten zinc forms a bond with the steel, creating a protective layer on the surface of the part.
Precision Grinding: Processes, Tolerances, and When To Use It
Most engineers have a solid feel for what CNC machining can do. But far fewer have a clear picture of what to do when conventional CNC process capabilities are exceeded by the need for tighter tolerances, finer surface finishes, or hardened work material that quickly wears through machine tools. When that happens, manufacturing engineers move […]
CNC machining is commonly used to manufacture various medical devices—surgical instruments, fixtures, structural elements, fluid-handling parts, and components that attach to or form part of a tissue-contacting implant. The machining operations themselves are familiar shop-floor work. The practical difference in medical device machining is that material definition, surface condition, traceability, inspection, and documentation aren’t just […]
